1993 Volvo 240 Head Lights
155,217 MILES • 4 CYL • 2WD • AUTOMATIC
BLROLAND
I have a 1993 Volvo 240 sedan that will not burn the dim headlights. I have replaced the dash switch, the turn signal head lamp dimmer switch & the head lamp relay switch. So far I have the same problem I started with no lights unless I hold the bright switch on while I drive. This is a starnge problem & I was hoping someone somewhere may have had the same problems ? blroland
Mar 2, 2010 at 3:02 AM
DAVE H
  • 13,383 POSTS
check the electrical connections are good
Mar 14, 2010 at 10:50 PM
