1993 Volvo 240 coolant leaking
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
SILVER33
I changed thermostat & everything OK one hour later I restarted engine & now have coolant leaking from either water pump or front of cylinder head any ideas as to why it started leaking? no leaks before.
thermostat was stuck open for about 8 months thats
why i changed.
Thanx Rick.
Feb 9, 2008 at 12:08 PM
  • 31,937 POSTS
You will have to pressure test the system to pin point where the leak is, sometimes these thing do happen, a new leak starts for no particular reason. do a pressure test first.
mark (mhpautos)
Feb 9, 2008 at 3:55 PM
