1992 Volvo 240 FIRING ORDER
STEWARTENTERPRISE
1992 Volvo 240 4 cyl Two Wheel Drive Manual
NEED FIRING ORDER FOR 1992 VOLVO 240 GL
Jan 31, 2009 at 8:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Below is firing order for 2.3L 4 cylinder engines of the Volvo 240 series. Let me know if your engine size differs and I will post correct firing order for that engine. To avoid confusion, remove and tag the spark plug wires one at a time, for replacement. If a distributor is not keyed for installation with only one orientation, it could have been removed previously and rewired. The resultant wiring would hold the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason, it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes in your book to reflect how your engine is wired. 2.3L 4-Cylinder Engines Distributor Rotation: Clockwise
https://images.2carpros.com/forum/automotive_pictures/261618_0900c1528008c45d_1.jpg
Thanks for using 2CarPros.com!
Jan 31, 2009 at 9:30 AM
AE921991
would you have the firing order for a 4afe Toyota Corolla 1600cc 16valve
Jan 1, 2010 at 9:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1389.jpg
Jan 4, 2010 at 11:29 PM
