1990 Volvo 240 Windshield Wipers
1990 VOLVO 240
18,000 MILES • 6 CYL • 2WD • AUTOMATIC
RUSSMORR
Windshield wipers will not operate on my girlfriend's 1990 240 DL - we've checked fuse associated with wipers (and I think two other components are on the same fuse and they are working).
Could it be the motor itself or the steering column-mounted wiper control switch (toggle stem type)? Please advise. Thanks.
Russ Morrison
Sep 27, 2009 at 3:35 AM
IMPALASS
  • 3,112 POSTS
Hello Russ
Was the fuse you checked Fuse 2, 16 amp and did you check it with an ohm meter to ensure it was good?
Put disconnect the connector and put 12v on the motor and ground and see if the motor runs
Sep 27, 2009 at 7:42 AM
