1990 Volvo 240 Brakes not working
1990 VOLVO 240
127,000 MILES • 4 CYL • 2WD • AUTOMATIC
JLR240DL
I replaced the calipers, rotars, and the brake pads, but they don't work at all. The brake pedal goes all the way to the floor, without any response. I checked for leaks, but there are none. What could be the problem?
Sep 4, 2008 at 3:01 AM
DOCFIXIT
  • 18,828 POSTS
Did brakes work before repair? If so did you bleed air out of system?
If no brakes before repair then master cylinder is the culprit.
Sep 5, 2008 at 5:12 AM
JLR240DL
The brakes worked before i replaced the calipers, etc. sounds like I need to bleed my lines then. how should i go about doing that?
Sep 5, 2008 at 7:29 AM
DOCFIXIT
  • 18,828 POSTS
Go to the site menu and click on How to Repair or Service. Then click on #16 how to bleed brakes. Then click on video of how to bleed.
Sep 5, 2008 at 7:42 AM
