1989 Volvo 240 oil light is on
1989 VOLVO 240
160,000 MILES • 4 CYL • 2WD • MANUAL
CAMARO701
last day in 25 below weather I noticed the oil pressure light on . I parked the car and waited to check it later Started up easy, lots of oil on dip stick. Wondering How do I check to determine if it is the oil pump or the sendor or a sensor that is screwing up? Does a 1989 Volvo have a diagnostic check that would determine the problem? I do not want to drive it if there is no oil pressure.
Feb 3, 2008 at 1:02 PM
BLACKOP555
  • 10,386 POSTS
you will have to use a manual oil pressure guage, if the pressure is low then its a pump/oil issue, if pressure is high and fine then the sendingunit/ switch is no longer functional.
Jul 17, 2008 at 11:08 AM
