1989 Volvo 240 gas
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
RASHEEDM5
my 1989 volvo burnsgas like a v8 and worse i put 20 dollars in and i got like 8 miles a gallon and i replaced the air folw sensor and it does not want to switch gears 3- 4 when it warms up do you know what that is .
Jun 17, 2008 at 9:26 AM
RASHEEDM5
[quote:4d40289185="rasheedm5"]1989 Volvo 240 4 cyl Two Wheel Drive Automatic 120000 miles
my 1989 volvo burnsgas like a v8 and worse i put 20 dollars in and i got like 8 miles a gallon and i replaced the air folw sensor and it does not want to switch gears 3- 4 when it warms up do you know what that is .[/quote:4d40289185]
Jun 17, 2008 at 11:03 PM
RLCULPEPPER
I had exaclty the same problem, until just today! It was the "Overdrive Relay." It appears to be a common problem. After looking for the part everywhere with no luck, I found some online for $80 + Tax and S/H. (and a lot of risk) I just stopped by the dealer and picked one up for $120.00 total, installed it myself (VERY easy) and I am back to normal.
Jun 19, 2008 at 6:16 AM
