1987 Volvo 240 Turn signals inop
1987 VOLVO 240
LANDRUS
  • 16 POSTS
Electrical problem
1987 Volvo 240 4 cyl Two Wheel Drive Manual
Last week my turn signals stopped working. The hazard lights still function so I believe that the relay is still ok. There is power to the fuse and the signal stalk but the signals themselves do not work.
Sep 4, 2008 at 9:23 AM
2CARPRO JACK
  • 11,533 POSTS
t/signals adn hazards share teh same flasher, so you may be looking at a bad turn signal switch.Do they light up at all? if not and there is power in and the hazards work it could be the switch
Sep 5, 2008 at 12:57 AM
LANDRUS
  • 16 POSTS
Is there an easy way to check the switch before I invest the cash?
Sep 5, 2008 at 4:43 AM
2CARPRO JACK
  • 11,533 POSTS
check for power at the blue(right) and green(left) wires at the column with theturn signal in right turn then left turn
Sep 6, 2008 at 1:17 AM
LANDRUS
  • 16 POSTS
hmmmm, a strange thing happened today. The seat belt light and a buzzer turned on when I put the switch in both positions. Then the signals began to work. Does this indicate there is a short or a ground issue? If so, where is the ground for this circuit.
Sep 6, 2008 at 11:18 AM
