1987 Volvo 240 rEPLACEMENT OF in tank FUEL PUMP
1987 VOLVO 240
DAVEMUSO
Electrical problem
1987 Volvo 240 4 cyl Two Wheel Drive Automatic
REPLACEMENT OF in tank FUEL PUMP
How do I do it, as I was told that this model
has 2 pumps one under the bonnet somewhere and the other is apparently inside the petrol tank.
Bit stuck here guys!
Davemuso
Sep 21, 2010 at 6:25 PM
VOLVO SERVICE ADV
  • 175 POSTS
THE PRE-PUMP INSIDE THE GAS TANK IS REMOVED THROUGH THE TRUNK. REMOVE THE UPHOLSTERY COVER TO GET TO ACCESS PANEL. REMOVE ACCESS PANEL AND PRE-PUMP IS INSIDE.
Sep 22, 2010 at 3:43 AM
