1987 Volvo 240 ACELERATION
1987 VOLVO 240
15,600 MILES • 6 CYL • 2WD • AUTOMATIC
NBKBQD1
AFTER STARING CAR AND GOING AT LOW SPEED AND STOPPED AT LIGHT OR INTERSECTION I HAVE HESITATION
Sep 16, 2010 at 2:18 PM
  • CERTIFIED EXPERT
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 16, 2010 at 4:32 PM
