1985 Volvo 240 Engine runs choppy
170,093 MILES • 4 CYL • 2WD • AUTOMATIC
JEROMEHYL14
Engine starts then will not idle. It does run poorly if the throttle is worked. If the throttle is not constantly pumped the engine dies.
May 18, 2008 at 12:26 PM
HATTRICK313
I had a 1990 240 DL that acted the exact same way and was real weak on acceleration. try putting a new mass air flow sensor in, it fixed mine and those always go bad on those cars.
May 30, 2008 at 6:00 PM
