Good morning.
The first thing you need to do is have the harmonic balancer fixed. It needs to run true. It may be incorrect, damaged or installed incorrectly.
Once that is done, have the charging system checked for proper voltage. With the pulley moving, the belts are tight and lose and that will affect the charging system.
SPONSORED LINKS
Tuesday, March 5th, 2019 AT 3:19 AM
