Voltage regulator
1995 JEEP CHEROKEE
200,000 MILES • 2.1L • 4 CYL • 2WD • MANUAL
JULIO MEDINA
i took out the ECM from my vehicle. I was told i could fix the soldering to the voltage regulator. is there a diagram i can get that shows me the circuit board in this ECM so i can pinpoint the regulator?
Jan 6, 2019 at 11:48 AM
  • 110,244 POSTS
There is no repair manual or schematic showing this. The manufacturer considers it a throw away part.
I wouldn't recommend trying to fix it, but if you do, you need to look for cracked or broken solder joints. Not an easy thing to fix. Make sure none of the solder crosses other circuits when repairing and make sure when heating the circuit board that nothing else is damaged.
I wish I had a better answer.
Jan 6, 2019 at 12:35 PM
