Voltage regular
14,500 MILES • 6 CYL
JIM MATHENY
Is the voltage regulator built into the alternator?
Aug 2, 2017 at 1:06 AM
STEVE W.
  • 15,409 POSTS
Yes and no. The regulator itself is in the alternator but it gets a control signal from the ECM to actually operate. What is the issue you are having?
Aug 2, 2017 at 1:17 AM
GREENBAYPACKERJIM
Not charging the battery and drains out when ever the air or lights are on.
Aug 2, 2017 at 4:39 AM
GREENBAYPACKERJIM
Yes. Will jump start and as soon as you turn one or the other on. Battery store checked the battery
Aug 2, 2017 at 4:57 AM
STEVE W.
  • 15,409 POSTS
Have an actual charging system test done not just a battery load test. It sounds like you have a bad alternator but it could also be that the unit isn't being controlled properly or has a bad cable to the battery. A system test can show where the issue actually is.
Aug 2, 2017 at 6:54 AM
GREENBAYPACKERJIM
Thank you. Would Auto Zone or someplace like that do it?
Aug 2, 2017 at 10:34 PM
STEVE W.
  • 15,409 POSTS
They have the tools, but most of the counter people do not really know how to use them very well.
If you have an AC/DC volt meter (even the cheap/free harbor freight ones will do for this) you can do a quick test. Check battery voltage with the engine off, now test it with the engine running.
EOV - 12.6 VDC on a fully charged good battery.
ERV - 13.6 - 15.0 VDC with a good alternator.
Switch to AC and you should see less than 1/2 volt AC. any higher and the rectifier has at least one bad diode.
Aug 2, 2017 at 11:44 PM
GREENBAYPACKERJIM
Thank you. I will try that
Aug 4, 2017 at 1:24 AM
  • 55,694 POSTS
Steve W. is one of our best.
Cheers, Ken
Aug 5, 2017 at 3:03 PM
