Voltage issue and fuel gauge not working
179,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
GRIMLIN13
My alternator went out so I replaced it and now my fuel gauge isn't working. My vehicle will not hardly climb a hill do to power loss and it will not take full pedal of fuel with out popping and falling on its face. it will barely run 55 miles an hour I have to let it build up speed and it takes forever to get there and then if I hit a hill it losses all power.
Mar 5, 2019 at 11:59 AM
  • 110,251 POSTS
Based on your description, it sounds like the fuel pump is weak and not an electrical issue. Do me a favor. Check it for diagnostic trouble codes. That way we will know if it is an electrical issue or not.
Here is a link that shows how to retrieve codes on an OBD1 system like this:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Also, since you had things apart prior to the problem, recheck you work. Make sure nothing was left disconnected such as vacuum hoses, sensors.
Let me know if you find a code. Also, consider checking fuel pressure and for vacuum leaks. Here are a couple links that you may find helpful:
Mar 5, 2019 at 12:39 PM
