Interior lights keep going out. Voltage drop at the fuse fox. Fuses keep blowing. Car is listed above Flying Spur.
Feb 26, 2019 at 3:57 AM
✓Experienced Mechanic
The first thing you should do is remove the interior light bulbs, I have seen the bulbs melt causing a short. Can you please shoot a quick video or images with your phone so we can see what you are talking about? that would be great. You can upload it here with your response.
Feb 28, 2019 at 4:33 AM
STUART WOLK
MEMBER
There is a voltage drop at the fuse box. Fuses tend to blow out under load and the lights themselves do not blow and when the voltage drop occurs the lights go out but they do not blow. The fuses governing the interior lights on the other hand do tend to blow. All relays are good.
Feb 28, 2019 at 4:47 AM
I would start by checking the bulb sockets. This is where the problems occur nine times out of ten. Can you upload some pictures of the bulb sockets?
