FOUND REAR WHEEL LOOSE. UPON INSP FOUND BOLT THAT CONNECTS WHEEL TO AXEL LOOSE. HOW TIGHT SHOULD IT BE AND WILL IT AFFECT WHEEL BEARING?
Jan 10, 2009 at 6:21 AM
MECHTRIX
✓Experienced Mechanic
hi" in response to your question" { yes } it does affect your wheel bearings if you are not shure ' have it checked by a mechanic "asap" . good luck i hope this helps .
Feb 9, 2009 at 6:44 AM
