1997 Volkswagen Van Temperature Warning light
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
BJ SMITH
The coolant warning light keeps flashing even though the coolant level is barely below the minimum level. Is the coolant level indicator that sensitive?
second question. This is a Winnebago modified VW Eurovan. There is a warning buzzer that keeps going off which we cannot find, not do we know what it is buzzing for. It seems to be directly above and to the right of the driver's head, not in the pop-up unit, but directly infront of it. The buzzer stops buzzing when the van is running, and starts soon after it is turned off. It sounds about every 45 seconds. What gives?
May 16, 2009 at 5:58 AM
DR LOOT
  • 2,311 POSTS
Yes it is that sensitive, you cannot drive with the coolant level below minimum as you have stated, the buzzer sound you're hearing is the warning buzzer for the low coolant, you remind me of the blind leading the blind, will they both not ruin their car?
Jul 11, 2009 at 9:45 AM
