1990 Volkswagen Van possable ignition switch problem
1990 VOLKSWAGEN VAN
COOLPAPA1
Electrical problem
1990 Volkswagen Van 4 cyl Two Wheel Drive Manual
turned switch, engine started. turned off then turned on again, engine started. next time turned switch nothing still get buzzing sound with key ,all lights work etc poss. bad switch? how would I check this?
Oct 12, 2009 at 4:07 AM
DR LOOT
  • 2,311 POSTS
It sounds like the ignition switch is working properly, check your wires down at the starter, because the starter is exposed to the elements of the road. Lots of times the cables are corroded.
Nov 27, 2009 at 1:32 AM
