1989 Volkswagen Van wheel bearing cap removal
194,000 MILES • 4 CYL • 2WD • MANUAL
JETTMARY
how does the front wheel bearing cap come off? I've removed the locking ring so now does the square headed "bolt" unscrew and in what direction or does the cap come off over the "bolt'?
Jan 10, 2009 at 1:44 AM
ALBRASE
  • 7 POSTS
That square thing is the drive end of the speedometer cable. The bearing grease cap will just pull off over it.
The cap itself is a light press fit, so you need to tap it along the inner rim to get it off. (There are special tools made to do it, but I've never bought one.)
BTW, when putting it together, you can pull the cable end out a little to line up with the square, then tap the cap on gently.
Jan 18, 2009 at 12:54 AM
