1989 Volkswagen Van Coolant Leak
1989 VOLKSWAGEN VAN
240,000 MILES • 4 CYL • 2WD • MANUAL
SIOUXCHEF
I have a 1989 Vanagon Carat edition, this is my first, and here is the problem:
-Lost my Alternator/Water Pump Belt, as a result the Engine overheated on the highway and sprayed antifreeze everywhere.
-Replaced all of the belts and filled the engine back up with coolant. Noticed a fairly rapid coolant leak under the engine above the oil pan.
-Engine Runs, but leaks very quickly. Is this my head Gasket? or does it sound like something else?
May 8, 2010 at 8:09 AM
  • 31,937 POSTS
Hi there,
This will have to be viewed first hand to make sure what it is, a mechanic can do a cooling system pressure test and locate this leak and identify the cause very quickly.
mark (mhpautos)
May 8, 2010 at 8:16 PM
