1985 Volkswagen Van Sometimes my car won't start
21,000 MILES • 4 CYL • 2WD • MANUAL
CK2
My V
My Kombi Van runs perfectly once running. But sometimes it won't start. It cranks fine with spark and fuel tested and available but will not start. Sometimes it happens when it's hot,; other times it occurs when it's cold. Is this an ignition problem involving the coil?
May 3, 2009 at 4:36 PM
DR LOOT
  • 2,311 POSTS
if I were you I would check all of the wire connections is specially at the distributor, make sure your battery cables are clean.
Jul 11, 2009 at 9:47 AM
