1978 Volkswagen Van renovation project
1978 VOLKSWAGEN VAN
120,000 MILES • 4 CYL • 2WD • MANUAL
HARDIE775
  • 10 POSTS
I have a 1978 VW van with about 120000 miles that's been sitting, without ANY movement for at least 5 years now. What do you suggest I do before I turn it over for the first time. It's been suggested to drain the gas etc.. should i drain, flush and refill all the fluids. I'm anxious to turn this thing over but i don't want to create more problems.
ALSO; Where might i go, weather via the internet or physically to obtain info to complete this renovation quest.
Thanks
Mar 23, 2009 at 8:05 AM
RACEFAN966
  • 5,029 POSTS
Ok first off you will need some seafoam for the tank and for the cylinders. I would pull out the spark plugs and put about a cap full of seafoam in each cylinder and turn it over by manually to ensure all it freed up. Then I would drain the fuel tank and put in some new fuel like 5 gallons or so and add the rest of the seafoam. Then change the oil and filter and put in a new fuel filter too. After all this is done then attempt to wake her up.
Mar 23, 2009 at 8:20 AM
