1970 Volkswagen Van Valve cover leaking
1970 VOLKSWAGEN VAN
136,000 MILES • 4 CYL • 2WD • MANUAL
ADAMANTADAM
My valve cover on one side is leaking oil badly, can I use gasket maker to seal it without effecting the next valve adjustment? Will I be able to get the valve cover off if I do, and if I can't use gasket maker, how do you suggest I solve the issue? Thanks for the info!
Jan 11, 2010 at 4:24 AM
DR LOOT
  • 2,311 POSTS
The valve cover comes off very easy, just take a large screwdriver in the center of the clip and pulled down, valve cover gaskets are only about $12 for the pair
Due to the high level of no responses to post questions, if you have not resolved your issue and you need further assistance, please respond.
Jan 19, 2010 at 1:40 AM
