My valve cover on one side is leaking oil badly, can I use gasket maker to seal it without effecting the next valve adjustment? Will I be able to get the valve cover off if I do, and if I can't use gasket maker, how do you suggest I solve the issue? Thanks for the info!
Jan 11, 2010 at 12:24 PM
