1992 Volkswagen Truck poor acceleration
1992 VOLKSWAGEN TRUCK
285,000 MILES • 4 CYL • FWD • AUTOMATIC
DOUG GLPVER
my vehical will get up to speed if i am patient. when i accelerate the engine,the vehicle slows down significantly. what may be the problem/solution?
Apr 23, 2010 at 2:24 AM
Hi Doug Glpver, Welcome to 2carpros and TY for the donation.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Apr 26, 2010 at 8:04 AM
