2009 Volkswagen Touareg VIBRATION/ HUMMING NOISE
2009 VOLKSWAGEN TOUAREG
SHIBBU
Shakes or Wobbles problem
2009 Volkswagen Touareg 6 cyl All Wheel Drive Automatic 8000KM miles
I GET A VIBRATION AT THE SPEED OF 140 KM. IT IS NOT WHEEL BALANCING PROBLEM, AS THE THE WHOLE BODY STARTS A SLIGHT VIBRATION. AS SOON I SLOW DOWN TO 130 THE VIBRATION GOES.
ALSO THERE IS A GRINDING/ HUMMING NOISE AT A LOW RPM I,E 800 TO 1000RPM.
VW DEALER SAYS THE VIBRATION IS DUE TO FAULTY REAR DIFFERENTIAL AND HAVE ORDERD FOR THE PART. DO YOU THINK IT WAS A CORRECT DIAGNOSIS. APPRECIATE YOUR HELP IN ADVANCE
Aug 19, 2009 at 9:58 PM
PAULJAMES
  • 22 POSTS
Hi
I know that this is an old post, but was the issue sorted out with the new rear differential that was ordered??
Thanks in advance!
Jan 6, 2010 at 8:30 PM
