2004 Volkswagen Touareg HEAD LIGHT
2004 VOLKSWAGEN TOUAREG
40,000 MILES • 6 CYL • AWD • AUTOMATIC
STEVE LUFRANO
HOW DO I REPLACE A HEAD LIGHT THAT HAS BURNED OUT
Feb 28, 2009 at 10:36 AM
IMPALASS
  • 3,112 POSTS
Hello - I believe this is the info you are requesting. Headlamps, removing and installing NOTE: "¢ It is not necessary to disconnect battery. "¢ Illustrations depict removal and installation of left headlamp. Removing: "¢ Switch off ignition, switch off all electrical components and remove ignition key. "¢ Press against headlamp. Fig. 267: Turning Locking Bolt In Direction Of Arrow Open (Sticker) Courtesy of VOLKSWAGEN UNITED STATES, INC.
https://images.2carpros.com/forum/automotive_pictures/248015_F267_1.png
"¢ Turn locking bolt - arrow - in - direction of arrow Open (sticker) - until resistance is felt. NOTE: "¢ Do not use force to turn bolt further, otherwise the locking mechanism will be destroyed. Headlamp is pushed toward front. "¢ Pull headlamp out of opening on body until resistance is felt. Fig. 268: Identifying Locking Clip Courtesy of VOLKSWAGEN UNITED STATES, INC.
https://images.2carpros.com/forum/automotive_pictures/248015_F268_1.png
"¢ Hold locking clip - 1 - pressed - arrow - and remove headlamp from opening on body. Installing: Fig. 269: Identifying Guides Courtesy of VOLKSWAGEN UNITED STATES, INC.
https://images.2carpros.com/forum/automotive_pictures/248015_F269_1.png
NOTE: "¢ Guides - arrows - must be free of dirt. "¢ Check connector - 1 - in headlamp mount for proper fitting before inserting headlamp into guides. "¢ Set headlamp into guides - arrows -. "¢ Slide headlamp into opening on body. NOTE: "¢ A significant "clicking" must be audible. Securing clip engages. Fig. 270: Turning Locking Bolt In Direction Of Arrow Open (Sticker) Courtesy of VOLKSWAGEN UNITED STATES, INC.
https://images.2carpros.com/forum/automotive_pictures/248015_F270_1.png
"¢ Turn locking bolt - arrow - in - direction of arrow Close (sticker) - until resistance is felt. "¢ Press lightly against headlamp and turn further in - direction of Close arrow (sticker) -. Securing bracket must engage audibly. NOTE: "¢ Do not use force to turn bolt further, otherwise the locking mechanism will be destroyed. "¢ Check installation position of headlamp for uniform gap dimensions. If the gaps are uneven in relation to body, headlamp position must be corrected → Headlamp installation position, correcting. "¢ Check headlamp for function.
Feb 28, 2009 at 10:51 AM
IMPALASS
  • 3,112 POSTS
Hello - Also, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
https://images.2carpros.com/forum/automotive_pictures/248015_Recall_8.jpg
Feb 28, 2009 at 10:53 AM
