2007 Volkswagen TDI Oil
33,000 MILES • 4 CYL • 2WD • MANUAL
SNEFFLE
ACEA A3,B3,B4API SL / SJ
10W-40
Can I use this Oil in my car to top it up?
I have a golf 2.0 tdi gt sport?
Feb 4, 2010 at 5:07 AM
DR LOOT
  • 2,311 POSTS
Negative!!! that is not Diesel oil if it was the quart would say so, you can only use Diesel oil in that vehicle
Feb 12, 2010 at 2:04 PM
LGHF
  • 6 POSTS
[quote:8509f57c17="Dr Loot"]Negative!!! that is not Diesel oil if it was the quart would say so, you can only use Diesel oil in that vehicle[/quote:8509f57c17]
"Dr Loot" you are wrong, Mobil 1 0w-40 says it is a gasoline oil, but VW has approved it for use in their pre-2004 engines.
No, a CJ-4 oil or VW 505.01 oil, not for use as fuel.
Apr 27, 2010 at 12:48 PM
