2006 Volkswagen TDI torgue pull
2006 VOLKSWAGEN JETTA TDI
110,000 MILES • 4 CYL • 2WD • MANUAL
VINNY0911
My alignment has been checked and is good. I just had new tires put on my car. My car pulls to the left due to torgue pull, once I press on the clutch the car stops pulling. Is there anyway to fix this?
Dec 2, 2009 at 4:57 AM
DR LOOT
  • 2,311 POSTS
Try checking your transmission mounts and your motor mounts, that is easy to do, just put your park brake on, with the hood open, , put it in first gear, slowly let out the clutch. If the engine twisted you got a bad mount, try the same procedure in reverse.
Dec 14, 2009 at 3:37 PM
