2006 Volkswagen TDI Thumping from engine, clutch or drive s
2006 VOLKSWAGEN JETTA TDI
50,000 MILES • 6 CYL • 2WD • MANUAL
MAGGIEMOON
My engine just started a regular thumping noise that cycles, about the speed of a slow heartbeat. Seems to occur when I have my foot on the gas pedal, but does not seem to be affected by pressing down or easing off of the clutch. I am noticing it when the car is in motion. I have not tried to press on the gas in neutral to see if the noise is still present. Would this be the symptom for a slipping clutch, for this is a comon problem with these models, or is it something else?
Jun 5, 2010 at 8:43 AM
DR LOOT
  • 2,311 POSTS
Check your air filter make sure it is secure, or it may be a tire that is coming apart.
Jun 15, 2010 at 7:32 PM
