Hi
Hope I can help with this.
The mirror cover needs to be removed first, the best way to do this is by gently lifting the plastic cover at the mount point on the door of the mirror housing. This is the strongest part of the cover, so it shouldnt crack. Before you do this, make sure the mirror glass is not in the way, best to push the bottom part of the glass in so that its not in the way when removing the cover.
Next, remove the glass from the mirror glass motor, there are a few plastic clips on the back of the mirror that can be opened with a flat screwdriver.
Once glass is off, you need a T15 torx screwdriver to remove 4 screws that hold the indicator lens onto the mirror housing. Note, you cannot replace the LEDs in the indicator alone, the unit comes complete and has to be replaced as such.
Hope this helps!
Jan 6, 2010 at 9:12 PM
