2003 Volkswagen TDI Engine power and noise
2003 VOLKSWAGEN JETTA TDI
BRAMLEY
Engine Performance problem
2003 Volkswagen TDI 4 cyl Two Wheel Drive Manual
Good day
I've taken my 1.9 tdi in for service 165000 and had the thermostat and waterpump replaced. When the car came back it had a noise in the area of the catalitic converter and had no power. I replaced the converter but realised the noise came from the airfilter box which was not properly closed.
I've closed the airfilter box but now the car won't start. If it starts it idles for a few seconds then dies. I can't ref it when it idles
Feb 14, 2009 at 12:05 AM
DR LOOT
  • 2,311 POSTS
your diagnosis doesn't make any sense, why dont you try rephrasing your problem with a little bit more information and I will try to help you.
Feb 26, 2009 at 2:40 PM
