I have a 03 Jetta TDI and it keeps turning the check engine lt on. The code is P0128. What is the fix for this
Aug 30, 2009 at 11:32 PM
DR LOOT
✓Experienced Mechanic
I am looking at the manual, but I do not see a code P0128, are you sure you have that correctly?I do have a P0228 which is the throttle positioning sensor, double checked the code and get back to me.
Sep 20, 2009 at 4:20 PM
TDI-CANOLA-POWER
MEMBER
p0128 code is "coolant thermostat/valve temperature below control range" ... you might want to get your thermostat checked.
