2003 Volkswagen TDI both headlight are out, fuses checked,
160,000 MILES • 4 CYL • 2WD • MANUAL
KAS139
Both headlights are our, however, my high beams and fog lights work. All fuses checked and look fine. Replaced both bulbs. Parking/Emergency brake is down. Any thoughts??
Jan 26, 2010 at 11:59 AM
DR LOOT
  • 2,311 POSTS
The low beam lights are operated by a fuse, fuses are very deceiving like women they may look good but they are bad, make sure you use a test light with the headlights on and check if you have power to both sides of the fuse.
Feb 12, 2010 at 2:13 PM
