2002 Volkswagen TDI Will service engine light go off
2002 VOLKSWAGEN JETTA TDI
83,000 MILES • 4 CYL • FWD • AUTOMATIC
KANSAS123
The service/repair manual I have says that the service engine light will go off after repairs are made 'sometimes' thru several engine cycles. No further guidance or explanations. I had the codes P0671 and P0674 tell me there were errors two glowplugs, so I replaced all 4 while I was at it, but the service light remains on. Is this one of the repairs that I can make and the service engine light will go off after several starts/stops cycles, or do I have to have someone with a scanner clear it? Thanks
Feb 28, 2010 at 1:48 AM
DR LOOT
  • 2,311 POSTS
the glow plugs are all hard code, you will need a scanner to clear them.
Oct 24, 2010 at 11:01 AM
