2002 Volkswagen TDI odometer button
98,000 MILES • 4 CYL • 2WD • MANUAL
SAUSAGES
Hello. My mk.4 2002 Golf tdi will not reset the odometer when I press the button to zero it.
This is a problem as i need to use this button to reset my service warning ! Any help will be much appreciated, thanks.
Feb 7, 2010 at 2:45 AM
DR LOOT
  • 2,311 POSTS
Obviously you've pressed it one too many times, I'm afraid you need a new cluster, I can probably fix it but you will have to send it to me.
Feb 12, 2010 at 2:01 PM
SAUSAGES
In the end, after stripping the clocks down I found a small piece of white plastic missing underneath the button. Someone else before me was obviously to heavy handed with it. Anyway, after butchering a pen lid, and a tube of glue later it's fine !! Not the recomended fix I know, but effective, and free may I add !! Thanks for the post, all sorted now.
Feb 16, 2010 at 5:26 AM
DR LOOT
  • 2,311 POSTS
I'm glad you fixed it, now be very easy on it.
Feb 16, 2010 at 1:08 PM
