2000 Volkswagen TDI Need Help with JETTA Turbo Diesel AC
99,000 MILES • 4 CYL • 2WD • AUTOMATIC
ZACH_SWEAT
Recently purchased a 2000 VW Jetta Turbo Diesel. The A/c has no problem blowing cool air through the vents, but it is definitely not as cold as it should be. Also, air has foul smell to it. I believe it may be a stopped up drain tube or something. Any help would be greatly appreciated.
Apr 30, 2009 at 2:29 AM
DR LOOT
  • 2,311 POSTS
nice guess but you are incorrect, the "foul smell" is probably a coolant leek, pull your mats up and check the floorboards and the firewall carpet make sure it is not wet, if it is wet you have a bad heater core, or something like that, is the vehicle using coolant? you can very easily check your air-conditioning system by taking the water hoes and cooling down the condenser, if the air gets colder you are low on 134A free-on.
May 11, 2009 at 1:56 AM
