2000 Volkswagen TDI diesel gelled up
DIESEL3276
Engine Mechanical problem
2000 Volkswagen TDI 4 cyl Two Wheel Drive 88000 miles
what should I do if the diesel gelled up? Do I need anything replaced if so how much would it cast and what should i do th prevent this again?
Dec 22, 2008 at 4:06 AM
BUDDYCRAIGG
  • 2,262 POSTS
you going to need to remove the fuel filter (or filters if you have more than one)
pour in some "power service 911" or "melt down" in the filters.
put the rest in the fuel tank.
and then to keep it from happening again, use something like "winter flow" as an additive when you get fuel.
Dec 25, 2008 at 9:22 AM
