2000 Volkswagen TDI
TNGUYENA
Engine Mechanical problem
2000 Volkswagen TDI 4 cyl Two Wheel Drive Manual
I have 2000 TDI VW new beetle it has 245K and the car start every time but it will not continue to run unless I spray the starting fluid. Anyone have any Idea what do I have to do to fixed.
My mechanic told me it is the injector pump but I just want to be sure before I put a lot of $$ into the new pump.
Please help
Thanks
Tony
Jul 20, 2010 at 6:11 AM
  • 75,988 POSTS
Hi tnguyena, Welcome to 2carpros and TY for the donation
Check the fuel filter if its clogged, air in the system and the injection pump solenoid.
Jul 20, 2010 at 11:11 AM
TNGUYENA
I do have all the new filters change out may be two weeks before this happen, I did check the glow plug, they all work.
I need to check the injector relay solenoid but don't know where they locate and how they work.
Please let me know how to check them.
Thanks
Tony
Jul 20, 2010 at 2:59 PM
  • 75,988 POSTS
Sorry I don't have any type of info on this Volks TDI in MIt1 and Alldata auto references on the injector relay solenoid. Its function is the same as a typical relay
Jul 20, 2010 at 6:10 PM
TNGUYENA
Any orther master mechanican that can help???
Please let me know how to test the injector pump and relay solenoid good or bad???
Thanks
Tony
Jul 21, 2010 at 2:50 AM
TNGUYENA
Just call the dealer and they said, they don't see any injector pump relay solenoid listed on this car???
Help
Help
Help
Help
Need help ASAP.
Jul 21, 2010 at 3:03 AM
  • 75,988 POSTS
Help
Help
Help
Help
Need help ASAP.
It doesn't have one you need to listen to the mechanic on the injection pump that's where the fuel originally gonna come from, if you have to be spraying it to keep it running. Get checked and tested
Jul 21, 2010 at 8:13 AM
