Engine Performance problem
1986 Volkswagen Scirocco Front Wheel Drive Manual
my car does not accelerate over 2rpm with the gas pedal to the floor. What is wrong?
Thursday, July 15th, 2010 AT 8:57 PM
DR LOOT
MECHANIC
Most likely it's the throttle controls switch those are the two micro switches that are activated by the throttle you can see them mounted on the throttle body check those for continuity
