2008 Volkswagen Rabbit Motor vent switch
32,000 MILES • 4 CYL • FWD • MANUAL
JONATHAN103813
The motor vent switch that controls where the air comes out does not work it keeps on popping a fuse what can be wrong? I installed a radio recently and had problems with the wires the a ignition wire (brown and red) burned. I had to cut of the wire because it was damaged. Please help.
Sep 2, 2010 at 1:18 AM
DR LOOT
  • 2,311 POSTS
You are going to have to remove the radio due to the fact that upon installation you may have pinch a wire that is causing a short remove the radio and let me know what you find.
Oct 6, 2010 at 4:00 PM
