1992 Volkswagen Rabbit Starting problem
109,600 MILES • 4 CYL • FWD • MANUAL
JASHIKA
  • 10 POSTS
Hi!
I have a strarting problem with my car: when the engine is at normal operating temperature sometimes if i want to start the engine the starter doesn't do anything.After 2-3 minutes the car starts perfectly.
Could it be the starter relay?The starter works perfect the battery is almost new.
Thank You
Peter
Feb 19, 2008 at 11:49 AM
BLACKOP555
  • 10,386 POSTS
does it click or nothing happens when the ignition is turned? try a new relay and have the battery bench tested.
Feb 19, 2008 at 12:33 PM
JASHIKA
  • 10 POSTS
The starter doesn't click.Only thing i can hear is the fuel pump... i'll just try the the relay.
Thank You!
Peter
Feb 20, 2008 at 5:28 AM
JASHIKA
  • 10 POSTS
Hi!
It turned out that there is no starter relay in the manual transmisson version.
I changed the ignition switch and it fixed the problem.
Than You anyways.
Peter
Apr 7, 2008 at 2:12 PM
