1984 Volkswagen Rabbit
MOPTOBY
Engine Performance problem
1984 Volkswagen Rabbit 4 cyl Front Wheel Drive
i've tried changing the distributer, plugs, wires, temperature switch, and o2 relay. it searches and misses at idle. runs good above 2500 rpm also tried a different ecm.
Nov 7, 2008 at 8:18 AM
DR LOOT
  • 2,311 POSTS
have you tried removing and cleaning the idol stabilizer? try that next, make sure you use carburetor cleaner, to clean out.
Mar 29, 2009 at 9:38 AM
