1983 Volkswagen Rabbit Out of gas before tank is empty
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
LBAUER42
I have a 10 gallon tank on this car. When full, the gas guage shows full and drops as expected as gas is used. However, I get just above half, and I run out of gas. I fill it up with 3.9-4.3 gallons of gas, and it's full again. The previous owner mentioned putting a new tank on it.
Is it possible that it cannot pull gas from the remaining 5.5-6 gallons in the tank? How can this be fixed?[img:57c10c2e42]http://www.2carpros.com/forum/automotive_pictures/568532_31759_1309702502230_1220611822_30722260_4049032_n_1.jpg[/img:57c10c2e42]
Sep 2, 2010 at 8:08 AM
  • 75,988 POSTS
Could be a problem with the gauge itself or the fuel sending unit
Sep 2, 2010 at 8:12 AM
DR LOOT
  • 2,311 POSTS
rasmataz It is correct it "Could be a problem with the gauge itself or the fuel sending unit" when the previous owner exchanged the fuel tank most likely he did not get it back together correctly, if you open up the back hatch pulled the carpet back on the right side by the back seat you will discover and access panel, remove the Philips screws the panel will come off and you will be looking at the sending unit, disconnect the fuel line and the return line, take a pair of channel locks pliers and twist the plastic collar counterclockwise, once the collar is removed you will be able to lift the fuel sending unit out of the tank. Once you have done you should notice a pick-up at the very bottom it might have fallen off and that is why you can not pick out the last 5 gallons, do as I have instructed and let me know when you find.
Oct 6, 2010 at 3:58 PM
