1982 Volkswagen Rabbit water pump
CCOMFORT
Engine Cooling problem
1982 Volkswagen Rabbit 4 cyl Front Wheel Drive Manual
coolant no longer circulating; must be pump as all belts and associated wheels are tight and turning; yes? what is reasonable labor time to replace the water pump? also, thermostat has failed - is this an easy replacement?
thank you very much for your time and concern,
CC
Nov 15, 2009 at 3:28 AM
DR LOOT
  • 2,311 POSTS
water pumps do not usually fail in circulation, it sounds like your problem is the thermostat, it is located on the bottom radiator hose at the water housing.
Nov 27, 2009 at 1:28 AM
