2007 Volkswagen Passat Whining noise in my 2.0 when I am in
2007 VOLKSWAGEN PASSAT
81,700 MILES • 4 CYL • FWD • AUTOMATIC
KKHUTCHERSON
I have a whine in my engine that starts up after about 5 minutes of driving or when the car warms up. This is only happening when I am in idle or decelerating, but not when I accelerate or when I am in reverse. The car runs fine, but just a few days ago my check engine light came on, but this is not rare with this car. When I shut the engine off, the whine sounds like a whistle as it shuts off for a few seconds afterwards.
Oct 1, 2010 at 3:13 AM
MERLIN2021
  • 17,250 POSTS
Get a can of spray gumout, start the car and spray around, pay attention to vacuum lines and manifold, if the idle changes, you found a leak. You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs!
The other possibilty is the idle air control, it,s bolted to the side of the throttle body...
Also do not spray hot exhaust manifolds or pipes, it can cause a fire!
You also want to read the codes, it can point you to the problem, Autozone will read them for free, post codes here.
Oct 1, 2010 at 4:31 AM
