2006 Volkswagen Passat Rattling noice
30,000 MILES • 6 CYL • FWD • AUTOMATIC
JUDY498
Hello there,
I have a 2006 volkswagon passat at almost 30,000 mileage. When I start the car up, there is a large rattling noise and when it runs for a little bit, it stops. But then when Im driving i can still here the rattling noise from time to time. Can you please tell me, what might be the problem and where I should take it too. I don't want to go the the dealership because they charge outrageously very everything.. Thank you, and have a good day...
Jul 28, 2010 at 9:54 AM
DAN~
Is the car not in warranty any more?
It could be the tappets (Hydraulic Lifters) need replacing or could even be the big end bearing.
I believe big end bearing is more of a knocking and makes you want to stop the engine straight away.
I suspect it's like the Hydraulic Lifters, have you checked there's the correct amount of oil in the engine? If not, top up straight away.
Aug 2, 2010 at 9:47 PM
