2006 Volkswagen Passat loss of oil
2006 VOLKSWAGEN PASSAT
ROBERT EHLENFELDT
Engine Mechanical problem
2006 Volkswagen Passat 4 cyl Automatic 25,000 miles
I leased a 2006 Passat. At 25,000 miles took it to dealer because of grinding noise under hood. Oil found to be 3.5 quarts low; engine was damaged beyond repair. No oil pressure alert appeared. No leakage where we parked. Filter housing found to be cracked. Valvoline last changed oil, 3500 miles earlier. VW attributes oil loss to cracked housing and assigns liability to Valvoline: no warranty coverage. Valvoline's inspector found no evidence of blow back. The vehicle had a previous low coolant warning. If oil had been lost through the broken filter housing, wouldn't a low pressure warning have illuminated? What would account for the loss of oil? VW suggests Valovoline did not add enough oil. Wouldn't a problem have appeared earlier, in that case?
Oct 16, 2008 at 8:13 AM
JAMES W.
  • 2,394 POSTS
The oil pump housing failure could have been caused by the overtightening of the oil filter. It may have been a defective casting from the factory. they may never know but I'm someone will catch the blame. The real issue is why the low oil warning light didn't come. Testing this circuit should tell the story. I am assuming the light never came on at "any" time. Even if the housing cracked on the way back to the dealer, there should have been oil dripping off the frame of the vehicle.
Oct 16, 2008 at 11:00 AM
ROBERT EHLENFELDT
Thanks for your prompt reply. It was I who got hit up for $8000: the cost of a new engine, installed. VW was uncoopoerative in looking for causes of system failure that did not fit their theory. They would not let me keep any damaged engine parts. They said they needed to return the core and to keep any part of it would cost an additional $2000.
Bob Ehlenfeldt
Oct 20, 2008 at 2:49 AM
JAMES W.
  • 2,394 POSTS
You got it "GOOD" and I'll bet you didn't even get kissed.
Oct 27, 2008 at 7:27 PM
