2006 Volkswagen Passat Engine shuttering in idle
52,000 MILES • 4 CYL • FWD • AUTOMATIC
TODDD
My wife stopped to get her morning coffee. When she started her car if began shuttering/vibrating in idle. IN gear the problem would get worst, until you got up to speed. The engine light came on after about five minutes. Checked oil, it was a little low, checked anti freeze, (temp ok)
Nov 4, 2008 at 2:44 AM
F4I_GUY
  • 3,302 POSTS
You most likely have an engine mis-fire and the MIL will properly read p0300 (random mis-fire)
You are due for spark plugs, have they been changed yet?
Dec 2, 2008 at 9:24 AM
FRANKWEST
  • 9 POSTS
the problem is a fualty crankcase breather vavle check codes and see if you have one for a leak in intake system and a code for system rich off idle
Aug 21, 2009 at 1:37 PM
